Correct, some conformal coatings are easier to deal with than others. The epoxy based ones I mostly work with are no fun.
Also, the dust won't harm the motherboard sitting on the coating.
If the whole thing is coated, you can set up a WC system with a sprayer head that continuously sprays the entire board, washing off any dust that is able to settle. Bonus distributed evaporative cooling!Well, a coating is easier to clean; you can wipe it with a cloth. Even a damp cloth.
There are also a handful of PC case fans available now that mimic industrial dust extraction systems, and run briefly at full-speed reverse on startup to clear the filter.
Ok, the real reason.
I simply hate the idea of dust touching my computer parts. My computer is always getting dusty, and it drives me nuts.
Air-tight case for components and separate, heavily filtered compartment for radiators would also work.
Nice try spam bot. Shrink wrap generates a high amount of static (which it uses to 'cling' to itself), and isn't something you want to wrap around ESD sensitive electronics.Covering entire motherboard with plastic, I think it wont work. Shrink wrapping can be quite good when compared to plastic packing.
