I have been going over some ideas and was wondering if any of you have found a good compromise between power supply sizing for a SFF build. SFX has high wattage psu's into the 800w range while dc-atx power supplies like the HDPlex and pico 150xt come in at a much smaller form factor but at much lower wattage ranges. Then of course you have the 1U server rack styled PSUs for builds that trade off on hieght but add in addition depth to the dimensions.
I am going to be trying my hand at a new case that has been forged from molten aluminum but I want it to be as small as possible since a solid cast of aluminum gets pretty hefty as you add volume to it. The main issue is trying to figure out what power supply(s) to go with. Im not set on the size yet but I know the components sizing and TDP values.
**Edited out**
Approximate TDP at load: ~500-550W
The question is whether I should go with the SX600-G I currently own or try my hand at a dual pico psu setup or a 1U psu. Dual HDPlex should be good for the TDP but I cant figure out if it would save more room then the SX600-G. Also for the 1U I found a slim version 600w 80+bronze manufactured by Superflower that is approximately 25% less height than conventional 1U power supplies. I probably wont go that way since I dont need to increase length for any real reason tho.
**Edited out**
