I am currently making some prototypes of a bracket which allows you to use the SFX PSU cutout on your case to mount a MEANWELL RPS or EPP power supply.
Why? You can combine these MEANWELL power supplies with an ATX plugin DC-DC PSU (picopsu) to free up some space in your case.
Why not support the HDPLEX 200W AC-DC? Because its 150mm long and therefore wont fit for SFX dimensions.
Target price: EUR 15,- incl. three PG7 cable glants and screws
Application example: you can free up space to use larger CPU coolers or for other stuff like custom watercooling components.
- Compatible power supplies: MEANWELL RPS & EPP 200W, 400W, 500W
- Compatible cases: should work with any SFX compatible case
- Mounting options: inside, outside, flipped vertical or horizontal, etc...
- Dimensions of the bracket: 130mmx64mmx2mm Aluminum
