SFF standard
tinyitx
2,273
2,334
Hongkong, CHINA
Sorry for asking a few newbie questions in this forum.
Is 20 litre the 'standard' definition of a SFF case?
Where does this 'standard' come from? Is it simply a general consensus of the community?
And, this 20L is the internal volume (vs external dimensions including the case feet...etc) of a case, correct?
Mar 6, 2017
501
454
I don't think it's an actual standard, just more of a general consensus. And when I refer to volume, I always mean external volume unless otherwise specified, but maybe I'm doing it wrong.
Reactions: cmyk78
Runamok81
Runner of Moks
Jul 27, 2015
446
622
Clemson, SC
troywitthoeft.com
General consensus. I think efficient use of space is really what we are about.
Rule of thumb: I'd say anything using full ATX mobos and power supplies is off the table.
mATX is upper limit... mITX with SFX power supply or DC-DC bricks are standard. STX mobo (5x5 inch) and and smaller are rare indeed.
7,953
Auckland, New Zealand
20 litres has been defined in Intel design documentation for some time. It is accepted that this is measured externally including all case feet and extensions. Internal volume is just cheating.
SFF Network has taken the above 20L external measurement as our definition for content production.
Reactions: tinyitx
Mar 6, 2017
501
454
Isn't the Cerberus X 19.5L?
ChainedHope
306
459
I always considered 2 things when deciding if something was SFF. If case volume is < 20L its SFF, if its not then space efficiency needs to be about 90%.
An example would be the new 8x mining rid in the build log section. Id consider it SFF because regular setups are usually MUCH larger and in their new designs are even more space efficient.
tinyitx
2,273
2,334
Hongkong, CHINA
Interesting idea you have. But I think it is hard pressed to call a packed 80-litre case (regardless how dense or sparse it is) a small form factor case. Maybe another category named SEF (space efficiency factor) should be used to designate such cases?
Reactions: SeñorDonut
VegetableStu
1,949
2,619
not sure where i got the 30L number from, but that's the max I feel ATX should be to be roughly SFF. (although there's the argument that ATX is unnecessarily large for most wants)
ChainedHope
306
459
Dunno why but your SEF comment made me think of a mini server farm lol.
The general idea is that if you can make something at a much smaller and denser rate than about 90% of the market, im going to call it SFF. Just because it might be "big" doesn't mean its not small in context.
As an example, a smart car is SFF compared to most other vehicles and vastly smaller than the lifted 4x4 trucks and suvs on the market. Different context, similar principle.
Reactions: owliwar and cmyk78
