Advice SFF build help - teen gaming comp
Sempsis
Building a SFF for transport between my house and my ex's house for the kiddo.
What did i miss? I already have a hdd and sdd.
I am 100% open to any suggestions (case needs to be small, light weight and portable (handle is needed)).
PCPartPicker Part List: https://pcpartpicker.com/list/bdJxYX
CPU: AMD Ryzen 7 8700F 4.1 GHz 8-Core Processor ($238.95 @ Amazon)
CPU Cooler: be quiet! Dark Rock Pro 5 CPU Cooler ($84.90 @ Amazon)
Thermal Compound: Thermal Grizzly Kryonaut 1 g Thermal Paste ($8.99 @ Amazon)
Motherboard: Gigabyte B650I AORUS ULTRA Mini ITX AM5 Motherboard ($179.99 @ Amazon)
Memory: Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory ($359.99 @ Newegg)
Video Card: MSI VENTUS 2X PLUS OC GeForce RTX 5060 Ti 8 GB Video Card ($379.99 @ Newegg)
Case: Deepcool CH160 Mini ITX Desktop Case ($103.00)
Power Supply: Corsair SF850 (2024) 850 W 80+ Platinum Certified Fully Modular SFX Power Supply ($178.99 @ Amazon)
Total: $1534.80
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2026-03-06 20:19 EST-0500
7,955
Auckland, New Zealand
I think the power supply is a bit overkill - a quick check on a PSU calculator shows the system should peak just below 450 watts. Then again, things aren't exactly getting more efficient as each generation of hardware comes along :/
Hopefully Deepcool and Be Quiet have their measurements right - the cooler is 168mm high, the case lists 172mm CPU cooler clearance. Tight!
Reactions: Sempsis
Sempsis
Thanks! Yeah i grabbed some of this from another person's build on pcpartpicker. They showed it fitting, but could easily be way to tight.
Reactions: confusis
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
3,104
4,594
46
France
guilleacoustic.wordpress.com
Looks solid overall, but that RAM price is insane 😅 You can get good 32GB DDR5-6000 kits way cheaper. Also the Dark Rock Pro 5 feels overkill for a portable SFF build, maybe go with a smaller cooler to save weight/space. Everything else looks pretty nice for a transport setup.
$359 for 2x 16GB@6000 is not bad. I don't know where you can get <way cheaper> prices in the currently AI RAMpocalypse situation.
