Log First build - advice
LizTheKid
Hi everyone,
I'm building my first SFF pc in the coming weeks. Putting a parts list together and looking for any advice or pointers, things you'd do different etc before I pull the trigger.
I've put a list together of what I'm looking at, the build centered around the Jonsbo TK-0 case. Primarily used for work tasks but no-doubt I'll be doing some gaming, so mid-tier performance should be sufficient.
What would you do differently? What have I missed.
Thanks for any feedback, it's appreciated.
PCPartPicker Part List
CPU: AMD Ryzen 7 9700X 3.8 GHz 8-Core Processor (£262.50 @ Amazon UK)
CPU Cooler: Noctua NH-D9L chromax.black 46.44 CFM CPU Cooler (£65.90 @ Amazon UK)
Motherboard: ASRock B850I Lightning WiFi Mini ITX AM5 Motherboard (£183.19 @ NeoComputers)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory (£105.92 @ Amazon UK)
Storage: SK Hynix Platinum P41 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£119.99 @ Amazon UK)
Video Card: Zotac GAMING AMP GeForce RTX 5060 Ti 16 GB Video Card (£428.99 @ Overclockers.co.uk)
Case: Jonsbo TK-0 Mini ITX Desktop Case (£149.00 @ Amazon UK)
Power Supply: Corsair SF850 (2024) 850 W 80+ Platinum Certified Fully Modular SFX Power Supply (£159.00 @ Computer Orbit)
Operating System: Microsoft Windows 11 Home Retail - USB 64-bit (£108.00 @ Amazon UK)
Total: £1582.49
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2025-07-28 11:27 BST+0100
CTFGaming
So a couple things here, you will be GPU bottle necked with this build so save yourself some money and go with a 9600x or wait for the 9600x3d unless you doing some cpu demanding tasks like video editing or rendering in which case I would suggest waiting for the 9700F which will be a far cheaper version of the 9700x with almost unnoticeably less clock speed. Also try get 6000mhz CL28 ram or even CL26 if you can find it or alternately a higher clock with higher latency, use this calculator to find the best combination: https://www.techpowerup.com/dram-latency/
Reactions: LizTheKid
LizTheKid
That's some really great feedback. Looking to order everything up next week, so will review the build based on this info. Thank you very much.
