Hi,
I'm considering building a new SFF gaming PC to replace what I currently have. It's been years since I've actually built one and I've never attempted one with major size constraints to consider. I was hoping your guys could help point me in the right direction.
The Goal:
A small living room PC dual booted with openelec (Kodi) and windows for gaming. The PC will be an always on machine for media playback that can also be booted to windows for heavy gaming. The PC should be quiet while playing media as it is not resource intensive but obviously might kick up to audible levels when gaming. This is to replace my current Alienware Alpha.
Ideal specs and limitations:
Medium/High performance Nvidia GPU - 1060 GTX Mini currently looks like the best choice
Medium Ram - 8GB/16GB ram
Medium CPU: i3/i5, prefereable skylake
Medium Budget - £400-£600 ideal range
And last but not least the size constraints, the area it's going is 32x27x32 cm (WxH) front and sides closed off with an extra 5cm open clearence at the back. Ideally I'd like to be able to fit my router in the same space and perhaps a PS4 (but not required).
The best case to fit the limitations I could find is the Lian-Li PC-Q21 (15x26x23 cm). The problem is I'm not sure that it's going to fit the 1060 Mini, the max length for the case is 170mm, which is exactly the same as the card, also the power connector on the 1060 mini appears to be facing directly where the side panel of the case is and I'm not 100% sure if this will be an issue.
You can see some shots of the case here with an R9 380 Compact, I think this is the exact same size as the 1060 Mini but with the power connector facing the front of the case instead:
http://www.hardwareslave.com/reviews/hardware/chassis/lian-li-pc-q21-mini-tower-chassis-review/3/
Also a shot of the 1060 Mini:
https://www.zotac.com/download/file...cards/zt-p10600a-10l_image5.jpg?itok=pNVFK6Aa
Is this likely to fit without issues?
Also any recommendations for alternative cases and opinions on whether the Q21 is going to be sufficiently cooled in the size constraints would be massively appreciated.
Thanks,
Ian
The Goal:
Thanks,
Ian
