I'm wondering if this graphene coating is safe to handle. I'd have to imagine if it made a noticeable difference we would see it more often.
Not sure my math is correctThey claim to give 30% better temps, but I really doubt it lol.
I don't think this is an accurate way of calculating temperature improvements; you get different results if you do this in Kelvin or Fahrenheit.Not sure my math is correct
If CPU is 90°C with uncoated heatsink, then 30% better temps should be 70°C (9000/130)
10°C better temps (65°C vs 75°C) is 15% better (7500/65)
So how is the x% better calculated?
That fan has a height of 15mm, which makes it too tall for the jitte. The jitte uses a 80x10mm fan on the bottom.Ok, this might sound crazy, but I found this
http://www.frozencpu.com/products/2...WM_Fan_TFD-9515M12ZPKERB.html?tl=g36c365s2188
This fan has 80 mm mounting points. Is this a way to maximize the potential of this cooler?
Well, it can be used for the top position then. I want to like this cooler, but those 80mm fans don't appear to cut it against the competition.That fan has a height of 15mm, which makes it too tall for the jitte. The jitte uses a 80x10mm fan on the bottom.
