SATA connector on HDPlex 160 - what are those called?
rsjo
41
88
I’m trying to see if I can find both housing and terminals for that 4 pin connector so I can make my own custom. I took one of the wires out and looked at the terminal but it didn’t look like either a Molex or a fan header terminal.
Are those available to buy and if so can they be assembled with the MDPC-C crimp tool?
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
Looks like a JST 2.54mm XH 4 pin connector.
I found a couple kits on amazon but they're all 100+ pieces and white :/ (not really expensive - around $10)
They also had a few kits with wire pre-installed on the connector so that could be another option. (still all white though)
I might look a bit more when I get home to see if I can find any black ones but that should at least point you in the right direction :)
Oh, and you should be able to crimp them with the MDPC crimpers - just use the smallest section
Good luck!
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
I also found this set of 5 connectors and terminals on ebay and it seems you can use dye to color the connectors black if you want.
Here's an article I found about dyeing. RIT Dye seems the popular choice though which exact product you would get depends on the plastic type of the part you're trying to dye.
Reactions: rsjo
rsjo
41
88
That’s exactly what I was after - I’ll be reusing the housing from the HDPlex as the one I just got actually had a black housing but needed terminals.
Thanks!!
Reactions: royalba94
6,075
5,007
Thanks for this, I was meaning to get to this one too, I need it for a custom connector. It's apparently difficult to find a black connector, the dye route seems to be not worth it for a part that's almost impossible to see due to the location.
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
Thanks!!
Your welcome, glad I could help :)
Np, glad my research back when it came out wasn't in vain ;)
Yeah, I agree - just figured I'd mention it cause some people (myself included sometimes) could drive themselves crazy for not having it match lol.
_______________
Good luck with both of your projects! :)
