This R-Cube 12.7L is a small case for a high -performance gaming PC. Despite the small volume in it, you can assemble a fairly powerful PC with a powerful cooling system. Easy enough assembly due to simple design. The case has several Display Port connectors with an internal cable for connecting a video card.
A two-slot video card up to 275mm long can be installed in the case. There is a cage for a 3.5 "HDD. For CPU cooling, you can install a Large Tower Cooler or a single-section AIO.
en.custmod.com
- Volume: 12.7L (302mm x 227mm x 185mm)
- Material: steel (1mm); aluminum (1,5mm)
Vertical installation of the motherboard: - MB: mini ITX; mini-DTX (170x215mm)
- Cooler: up to 155mm
- GPU: <275mm, <135*mm, <55mm
- Fan: 1 x 92x92x25mm
Horizontal installation of the motherboard: - MB: mini-ITX (170x170mm)
- Cooler: высотой до 170mm/
AIO: Radiator max 125x125mm + 2fan 120x25mm - PCIe riser: LiHeat 300mm type.B
- GPU: <275mm, <130*mm, <44mm
_______________ - PSU: SFX / SFX-L
- Storage: SSD/HDD: 2 x 2.5" / HDD 3.5"
- 22mm for connectors inside the case
* Front ports 2xUSB 3.0 + audio / mic reduce the permissible distance across the width of installed video cards by 15mm
![en.custmod.com](/forum/proxy.php?image=https%3A%2F%2Fstatic.wixstatic.com%2Fmedia%2F5bcca1_f0f2d8e13500440ba253e6f6443060cd%7Emv2.jpg%2Fv1%2Ffill%2Fw_1685%2Ch_1123%2Cal_c%2F5bcca1_f0f2d8e13500440ba253e6f6443060cd%7Emv2.jpg&hash=0575f193345db02e2f397a3656a0a4ec&return_error=1)
Case R-Cube 13L | SFF Cases Custom MOD
The Custom_MOD R-Cube 13L case won't take up much space on your desk.
![en.custmod.com](/forum/proxy.php?image=https%3A%2F%2Fstatic.wixstatic.com%2Fmedia%2F5bcca1_86132e91f2a64ff78e4cafbd325260de%257Emv2.png%2Fv1%2Ffill%2Fw_32%252Ch_32%252Clg_1%252Cusm_0.66_1.00_0.01%2F5bcca1_86132e91f2a64ff78e4cafbd325260de%257Emv2.png&hash=3a2524d7f6288f6c40765ba35caabdcf&return_error=1)
