First of all, few notes before my post:
1. I understand the risk of modding PSU, don't worry and please don't ask me to scrap the idea ?
2. Not opting for modularization as I think that the advantage is not much, you can only get rid of molex & fdd wire, probably another sata because the mobo, cpu, 2x PCIE wire are inevitable, and adding the connectors will significantly extend the PSU footprint. Instead of adding modular board, I think changing to soft silicone wire will be much better.
My question is, can we replace the wires from the PSU board? For example there are 30cm 4 yellow 4 black for CPU power, can we replace the 4 yellow (18awg) with only 1 wire (thicker, eg. 8awg), only split it to 4 wires 1 or 2 inches near to the connector?
Will that cause any problem? Assuming the wires are high quality, solder work is great. Will that idea work electrical wise? Need advice from electrician/engineer or whoever is experienced on this, thanks. ?
