Power Supply psu for a antek isk 300 (8 pin cpu motherboard)
WobZomby
Nov 12, 2018
Kirkwall, Orkney
Hey new to forum but I need some advice.
Am looking for a psu that I could fit in a antek isk 300 to repalce the bulky 150 watt, Ill be honest am unsure what I should be looking at.
My system hardware specs are
amd athlon 200ge (35 watts)
16gb of ddr4 ram
1tb and a 500gb 2.5 hdd (5400rpm)
120gb m.2
slim line dvd/rw
2x 80mm noctua pwm fan
and a noctua 65mm height cpu cooler
I might throw in a low profile gtx 1030.
Reason for the psu change is the case is second hand and unsure of the age and I know psu can degrade over time, also the cables are horrible to cable tidy.
Iv looked on amazon uk and itx store but got a bit confused as there's so many and notice a lot didn't have a 8 pin cpu something I do need due to my motherboard.
Is there such a thing as a pico psu that doesn't need the power brick out side the case? I did see the polarized c8 connector but get the feeling the hdplex will be over kill for my system.
I want to apologise about my grammar and spelling Iv tried best but some times even goggle auto correct is like WTF DUDE!!
Thehack
Mar 6, 2016
2,813
3,676
J-hackcompany.com
You don't actually need all 8 pin for the CPU. 4 is just fine.
You should be looking at an external kit, like the picopsu 160xt kit, and wiring it some way.
Or an internal kit like the hdplex 160 ac-dc and 160 plugin unit.
