Hello everyone,
I wanted to share with you my project, to have a powerful pc in an old glory, or the ps2 Fat in silver color, despite the problems and the creation of the connections was long and tiring I did not give up, in any case I had already ready bigger alternatives.
In reality it is not the first project in a "recovered" houses, I had for a short time a "small size" recovered houses with a sfx power supply.
I finished the components recently, even if it currently has too high temperature problems and are looking for solutions.
Below are the current components, although some are expected to change soon.
-Amd Ryzen 1600 (upgrade to Ryzen 2600 soon)
-Biostar x370GTN Mini itx
-Ram 16 gb 2400 mh Ballistix Sport LT
-Zotac Gtx 1060 6 GB Mini
-Noctua NH-L9i
-SSD Kingston 480 GB M2
-2 HdPlex 160w DC-ATX
-Power brick Dell 330watt
-Noctua 40mm soon
The riser is a generic $ 3, has always worked well only that it is not very flexible and in this case long.
I doubt whether to turn the gpu and put a long and flexible riser (which?) Or if you keep it so and given to take a very short riser.
All silicone cables (awg 18-20) have been wired by me to measure.
The black and white power cable is momentary waiting for the new keys to arrive.
The gpu supports were printed in 3D and I used the double-sided adhesive to attach a good part of the pieces. Let's say there is a lot of tape.
I have not done many photos in the course of work, but I put the finished work. The external part is the only thing I do not want to touch, it must remain as original as possible.
Any advice from the most experienced is always welcome.
-Noctua NH-L9i
-Noctua 40mm soon
