Prototype Portable industrial chassis with 17.3" screen
cmvrgr
I was thinking to invest in a portable pc and I found that chassis with 17.3" screen and mATX motherboard (there is a version of full ATX but the system becomes massive in size).
I have 3 problems.
1st problem is that mATX motherboards for AMD threadripper some say that they will not come to market at all and only full ATX will be available.
2nd problem it that there are only 114.5mm cpu cooling support and I do not know if using a coolmaster liquid cooling with a single fan (by making a hole for the fan and radiator plus the cpu pump) are more that 114.5mm in total compined.
3rd problem is the psu. This chassis using 1u psu 220mmx100mmx41mm and I could not find one more that 600w.
Will be on for a threadripper system with a Nvidia 1070, 2 x 3.5 hdd and 1x 2.5" ssd plus a slim CD Rom drive ?
If someone can help I will appreciate it.
Thanks
