Hi everyone!
First sorry for my english.
I'm a newbie planning first sff build with Ncase M1 v6.
The build would be for some regular gaming at 1440 ( for example witcher 3 or similar games,no hardcore Gaming) and for code development inside many virtual machines.
I prefer a build:
- quiet
- cool
- future proof
- air cooling
- good value performance with many cores (no manual overclocking)
I have a flex budget, but i'll prefer not to exceed 2-2,5k €
i read a lot of thread here and there, and i make this draft build:
https://es.pcpartpicker.com/list/CtFWV6
So i have some doubts and i'll be so gratefull with you can help:
- I've read some threads about fitting Noctua NH-C14S and in v5 model if want to use an 120mm in low profile mode you must place sfx psu in ATX layout with an M1 included adapter. 140 mm doesn`t fit. In v6 i've read that: Eliminated ATX PSU bracket. ¿How could i mount NH-C14S in v6 model? ¿can be with 140mm NF-A14 included? ¿intake or exhaust to vented panel?
- ¿Maybe other CPU coolers that performs better in v6?
-- If the Noctua NH-C14S fitting could be possible, ¿it makes sense to add a slim fan on top? ¿ and another 120x25 fan on the side bracket towards the front as intake?
- i prefer no chipset fans but i want a future-proof mobo for ryzen 3700x (i guess main concern is good VRMs) , ¿Asus ROG STRIX X470-I GAMING or B450I Gaming Plus AC? ¿maybe others?
- 32 Gb is a must for my development task (and the max. you can put in these mobos, 2 x DIMMs dual channel). I'ver read that for ryzen best value & compatibilty for x470/b450 is Bdie chips 3200 CL14 (Trident Z /Flare X). But for 32Gb there no sticks like: only 2933 CL14 or 3200 CL16. ¿Suggestions?
- Height RAM sticks Flare X 40 mm and Trident Z 44 mm. ¿With NH-C14S are there aby ram clearance issues? Noctua's FAQ said max 38 mm but i see some builds with Trident Z RGB that confirm it fits..
- ¿GPU Gigabyte RTX 2070 Super Gaming OC would fit? .. If answer i s yes, ¿is a good idea for temp and noise to keep its shroud fans and add 2 intake slim 120mm fans at bottom? I assume thick 25mm fans doesnt fit..
I know there are many doubt, but the more read the more doubt.. lol
Thanks in advance for your support!!!
I prefer a build:
- quiet
- cool
- future proof
- air cooling
