Hi all,
Long time lurker who finally decided to pull the trigger on ordering one of the new V6 M1s.
I've done a fair amount of research but wanted to see if there were any discrepancies or issues that any of the veteran Ncase builders may notice with my components.
The initial goal of this build was to create a small 4k gaming machine that will be hooked up to 4K TVs. I used the excuse of my son being born to convince my wife to allow me to build a new pc in his name
. Absolute silence is not necessary with the build but having cool-enough temperatures is a priority.
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor - Unsure if I'm planning to OC yet, but having the option is nice.
CPU Cooler: Noctua NH-U9S 46.44 CFM CPU Cooler - I've been bouncing back and forth between air cooling and attempting to do a full custom water cooling loop. The latter seemed like too much of a hassle for a beginner like me (having to both learn to build in a SFF AND learn water cooling for the first time). From research it seems like the U9S is the most friendly cooler out there.
Motherboard: Any X570 board for future proofing. Between the Gigabyte or ASRock
Memory: Team Dark Pro 16 GB (2 x 8 GB) DDR4-3200 Memory - extra RAM given to me by my brother
Storage: Any 1 or 2 TB M.2 SSD, I figured for just gaming purposes there was no need for a SATA SSD if I could get away with just a M.2
Video Card: RTX 2080 ti - I've searched and saw that someone was able to fit a 3 slot EVGA 2080ti XC card ( ). My question here is that do you guys think it is worth I cough up the additional $$ for a 2080 ti vs. just purchasing a 2070, 2080 super, etc? My biggest concern would be getting rid of the heat generated by a card as beastly as the 2080ti.
Power Supply: Corsair SF 600 W 80+ Platinum Certified Fully Modular SFX Power Supply
With regards to fans, I am thinking of placing:
- an additional 92 mm Noctua fan on the rear of the case for exhaust
- 1x A12x25 on the front-side panel as intake
- 2x Slim A12x15 fans on the bottom of the case as intake, blowing against the GPU
Any input you guys may have would be greatly appreciated. Thanks in advance!
