The new SFF buid will replace an aging secondary system in an Antec P150 tower, M4A79XTD EVO / Phenom II X2 550, Windows7, with a bunch of hard drives which at this point are mostly empty. The new system will run Linux, with some embedded development and a one or two light VM images.
It has been been many years since I built the above tower, so am not only struggling a bit with going SFF, but with the current status of technology. Your help will be appreciated. These are my initial thoughts:
- Streacom F1CWS (are there alternatives in similar dimensions)
- Motherboard ??? (good brand)
- Intel 35W TDP, i7-7700T or i5-7600T processor (I assume either will be a significant step up from the Phenom)
- 32GB RAM DDR4 ???
- Graphics, integrated... are they good enough nowadays for no gaming?
- WIFI if possible, in motherboard.
- A couple of SSDs, prefer 2x2.5, but if needed, one of them could be Msata.
- DVD slim drive
- Power supply, if possible, external brick with DC-DC in motherboard. If not, I guess something like a Pico.
As you can see I need help to make some decisions. Somehow flexible with the budget -- this box should last me another ten years (as the above one has) .
I will apreciate comments and suggestion
- 32GB RAM DDR4 ???
- DVD slim drive
