First of all, can I get some thoughts on this mini-itx build? http://pcpartpicker.com/list/FDM7dm
Any compatibility issues?
This is a build I'm planning for in the future. So far, only the case, riser and psu have been purchased.
I plan on incrementally upgrading part by part since I can't afford it all right now, with the gpu being last because it's the most expensive and the current gpu I have now is an rx 470 (which might hold me off for a while).
It shouldn't take more than a year. I just want to know if there is a problem with doing this. Like for example, if I buy the processor today, and find out months later that there is a better gpu in my price range than the 5700 xt, would the newer gpu not be as good with the cpu?
