PicoPsu 125W Build Advice
pcant94
Hi,I am building a SFF RV PC With M3-ATX 125W(Micro Atx),I was wondering If you Could Recommend A Cpu (Preferabbly Intel) with Low TDP?
2,201
2,225
What will the PC be used for? What is your budget? What case will you be using, and what cooling solution? Give us some more info, and we'll be able to lead you to a good conclusion, but without we'd pretty much be shooting blind :)
pcant94
Hi,The Pc Will be used for Basic Stuff such as Light Gaming,Internet and Watching Films.Regarding Cases It will be Sff (microatx),I have an athlon 220ge,35w tdp.Would this be suitable for the M3-ATX?. Are Embedded Intel/AMD Motherboards more suitable for this?.
