Enclosure Pico-Box Z4
ricochet
SFF AFFLICTED
547
345
Would the Pico-Box Z4 fair better with a lighter system operating well under 70 watts and using a 120W Brick?
Ultimately want this psu due to the beautiful silver wires!
ricochet
SFF AFFLICTED
547
345
I would expect so, plus it would run very cool I would hope!
Good day sir, I really appreciate the reply. What brick (AC Adapter Power Supply) would you recommend I buy for the Z4 then to properly power a sub-70 Watt system? I see that a 19V is recommended or would 24V be even better? 120W or higher? Also, which connector do I need to look for to ensure that it will fit this Pico-Box PSU? Cheers,
MarcParis
Apr 1, 2016
3,833
2,995
Definitely it will work fine.
As power brick, i guess if you can find a 240w dell (60-70€) you can go for it, as it can power a lot of devices
