Log Phat Aircooling Sunmilo C01s Build Log
nero626
61
217
Earlier last year AMD and Nvidia had my jaw dropped with the new 5000 series ryzen and 3000 series RTX, I knew it was time to upgrade, but my old build had a full custom loop, I didn't really want to maintain a loop again, pump was screaming at certain RPM, the blocks started discolorating, who knows what kind of deposit is in the rads, I've decided to go back to aircooling and start from scratch
As much as I like sandwich layout, imo it's only ideal with watercooling, low profile CPU coolers don't pair well with high power 8+ core CPUs, especially since I'm very sensitive to noise
I've noticed more and more people deshrouding their GPUs and getting near watercooling performance, at the same time I also luckily scored a 5800x and an ASUS dual 3070, which turned out to be one of the best card for deshrouding as the heatsink is as clean as it gets, no weird tabs and screws sticking out:
(pic cred u/DK426)
So I began searching for the smallest case that would fit this 3070 as well as a CPU cooler w/ 120mm fan, after being off the grid for 3 years I had to catch up with all the new SFF cases and news - it was amazing to see how much this community has grown, mainstream case makers seem be churning out decent and affordable SFF options now; I finally landed on a Sunmilo C01s:
This case ticked all the right boxes for me:
1. supports cpu cooler with full 120mm fans (Thermalright Silver Arrow 130)
2. fits my ASUS Dual 3070
3. tempered glass
4. decent airflow path, gpu gets fresh air from the bottom, cpu from the back and exhausts out the top
5. asap (as small as possible)
And somehow one was available on hardware swap canada? And the seller lives < 50km from me? So I had to pick it up.
And holy is this thing short, width and length is kinda similar to my old case but without the top and bottom rads that's probably where the extra 4-5L went
didn't take too many pics in the beginning.. sorry
First surprise.. this case doesn't officially work with deshrouded gpu, at least not with 25mm fans.. luckily I was able to just lift the bottom panel by 8mm with some stand offs, this doesn't look too bad but I'll get back to this later
GPU power cables were also sticking out like sore thumbs (literally), and I couldn't close the side panel at all, so I ordered some 180 deg adapter, custom cables, while I was at it I also ordered a silver arrow 130 off aliexpress.. and the seller never shipped the cooler and I was refunded after 45 days.. sadge
Second surprise, I was wondering why my gpu temps were terribad when gaming even with the fans at 1400rpm, like 95c throttling bad??
so I took the panel out and I was greeted with this
There was probably some ultra weird turbulance going on that was causing the air to basically recirculate around the hub, either the hole pattern sunmilo decided to put was just too small or poorly designed, or that there was some weird dynamics happening with the hole design and the fans, either way I gave up trying to figure out what it was and just cut out a massive hole on the bottom (that took a while), that brought it back down to 65c @ 1200rpm running cyberpunk.. phew
With the 180 deg adapter I can finally close the side panel
still waiting for the CPU cooler... sold out everywhere...
Surprisingly the rgb stealth cooler I had laying around isn't actually too bad albeit a bit noisy
At this point the build was at a state that I was 70% happy and so I started looking at mods to spice it up
So I was like, hmm the cables are kinda ugly, what if I cover it up with something... hmm maybe a screen??
Yess that's it, look ma no cables
nvm there's still cable outside.. I'll deal with that next time
Now this is pretty much where my build is as of now (Apr 01, 2021), I have a bunch of mods lined up so stayed tuned!
1. the legendary silver arrow 130, finally got my hands on one..
2. cleaned up bottom plate,
3. bottom spacer tray with moar RGB (white ring layer to hide the lifted 8mm spacer)
4. sicc 3d printed legs
5. better screen mounting
6. smoked side panel with better GPU exhaust, saw a 5c difference with and without the side panel on, even though it's getting fresh air the exhaust flow is probably still lacking
feet pic
That's it for now~
nero626
61
217
got my parts from shapeway!!
swapped out the cooler, it's insanely quiet, but 5800x is such a hot chip.. literally doesn't matter what fan speed I set it at and if the cooler is cool to the touch, with single core boost it will still hit 85+, it averages on 45 and gaming at 60 @1000rpm though, also got a slim noctua at the top to help with exhaust
installed the screen properly with the 3d printed mount
corsair commander pro is the most anti SFF component, why is it so damn big?
just need the laser cut parts next and I should be done for now..
BaK
966
957
Nice mods! :thumb:
I still wonder how the screen is held in place only with this T piece of plastic?
And how is the screen powered and connected?
Reactions: nero626
nero626
61
217
Nice mods! :thumb:
Thanks~
The screen is taped to the T plastic with some 3m removable double sided tape and the plastic is screwed onto an existing 2.5" drive mount on my case
The screen is powered by the internal usb hub through the corsair commander pro, so it technically draws power through the SATA connector, and the HDMI signal is routed through a slim cable to the back of the case
What is the screen actually?
Seconding this question, that screen looks really nice!
It's a tablet 7.9" 1536x2048 screen made by SHARP (lq079l1sx01), it's made for the ipad mini retina (I think? or maybe some clone of it), not sure if I can post aliexpress links here but if you search [1536*2048 7.9 inch ips] it should show up, you can get a full kit (screen + controller) for around $60, it's IPS and the color is very good, the only problem is that the brightness fixed and it's quite bright at 400 nits, it's alright with my tinted glass and you can kinda fix it with nvidia control panel brightness adjustments, but it's miles better than most RPI displays I see a lot of people use in terms of both color and resolution
EDIT:
To add on, because the screen is so high res it's quite usable as a secondary monitor for things like spotify or even discord, while I think having hardware monitoring is cool, I stopped looking at temps and clockspeeds after the first week of building this PC LOL, it's quite nice to have non important windows on this screen
or some karaoke while you work from home
2,201
2,225
Thanks~
EDIT:
Ah, so the controller doesn't have controls at all? I can definitely see how that might become an issue. Does it react to adjusting the brightness from the quick settings in the W10 notification tray (as a laptop would)?
nero626
61
217
unfortunately this controller is very basic, though according to the datasheet you can add a resistor to some pads to adjust the brightness, so I guess if you added a potentiometer you can have hardware brightness control, and sadly it doesn't support display data channel either so no brightness control via software
also there are other displays with better controllers, some have touch support, buttons for brightness adjustments or even full OSD adjustments and things like multi input and audio outputs, but those are a bit more expensive, this is my first experience with these display controllers but I'll definitely try other ones out in the future, they are pretty fun to toy with and with a proper casing I can see this being a decent option for portable displays
nero626
61
217
long time no see!
recently i upgraded to a 3090 to run bigger ML models and the height of the deshrouded heatsink is a little bit different than before,
and i just received my new bambu lab a1 mini so this is the perfect opportunity to test this little printer out!
i've wanted to redesign the feet for a while now but never got around to it until now,
i've always wanted to completely remove the bottom plate and mount my fans directly to the feet like this:
went through a few iterations until I settled on this:
pretty slick eh?
man the a1 mini has no right to be this good.. it's fast, relatively quiet, self calibrating, reliable, all for $200??? not sponsored but holy am i impressed..
lookin pretty good :)
the pc now sits slightly taller, more air for the gpu too!
i really hope the next gen GPU would fit in this form factor, nvidia please make a 24gb+ card that's shorter than 280mm....
  • Love
Reactions: BaK
