Phanteks Shift (Non X) Hardline Custom Loop
Hello! Just keen on getting some tips and advice on my current build.
I am currently doing a hardline custom loop in the Phanteks Shift case. However, i cannot fit a reservoir in the loop. I was thinking of running my loop as you would normally and have quick disconnects on the lines going to an external reservoir. Then once the loop is finished and all air is removed, simply removing it from the loop. This is my first custom loop, and only my second computer I've built so all advice is appreciated.
Amended Problems and Additional Work
I used 5mm Thermal Padding under the monoblock to touch the chips. The PSU has been moved to one side to fit the GPU behind it. Front exhaust fan has been moved to one side to accomodate the GPU's waterblock. I am unable to use the AIO pump header due to the monoblock but it isn't necessary. All fans are connected to the CPU header with adapters. All original RGB LEDS have been removed and replaced with custom UV Black LEDS.
Parts List
Intel 8700k delid @ 5.3ghz
Asus z370-I
Asus 980ti Strix @ 1500mhz
TridentZ 2x8G @ 4000mhz
Corsair SF600
Samsung 860 EVO x2 @ RAID0
Noctua NF-F12 industrialPPC-3000 PWM x2
NF-A12x15 PWM
EK-XTOP Revo D5 PWM
EK-CoolStream SE 120 x2
EK-FB Asus Z270i Strix Monoblock
EK-FC 980 GTX Ti Strix
EK-RAM Monarch Modual
EK-RAM Monarch X2 - Nickel
Mayhems Clear Sky Blue UV
Reactions: eunai
