Other PCIe X4 to M.2 (NGFF) Adapter Alternative?
Thestarkiller32
152
102
29
Deutschland (Germany)
So, using a u.2 card, and a board like that, would have minimal performance loss?
Jup, U.2 deliveres 4 lanes over the connektion.
Thestarkiller32
152
102
29
This card has a molex connecter and uses just the u.2 connector, (https://www.amazon.com/gp/product/B01DV7LF02/?tag=theminutiae-20), Where as this one uses (https://www.amazon.com/gp/product/B0199CECJ4/?tag=theminutiae-20) the sata type plug and no additional power. Which one should i use? The powered one, right?
...molex would be the better option I guess
Molex: 5V/GND/GND/12V
Each 12V Pin can deliver between 6-10 Amps witch equals to 72-120W(one device connected)
SATA Power: 3x3,3V/3xGND/3x5V/3xGND/3x12V
Each 12V pin can deliver up to 1,5 Amps witch equals to a total of 54W
PCIe Slot POWER (x1-x16) delivers 75W
...but they also produce that stuff sooo...
Free-shipping-15Pin-SATA-male-To-6Pin-Female-PCI-E-Graphics-Video-Card-Power-Cable-support.jpg
Thestarkiller32
152
102
29
So that's what ^ i would use, along with the 6-pin to sata adapter?
no not the adapter from SATA to 6-Pin... i meant with that, that they bundle that whit the graphics cards sometimes... maybe consider splißing the wires directly together... i cant get the AWG of the wires... if you get them, you could count the Resistance to ensure the safety.
Windfall
2,117
1,584
So basically, you are saying to have two sata connectors connected to the same cable on that u.2 to x16 adapter? And that would provide enough power?
jØrd
S̳C̳S̳I̳ ̳f̳o̳r̳ ̳l̳i̳f̳e̳
LOSIAS
Jul 19, 2015
818
1,359
Personally I wouldnt put that much power through a SATA connector but YMMV i suppose. It might be worth checking into power delivery a little, whilst x16 slots must be spec'd to deliver 75w anything less is (x8, x4, x1) only spec'd for 45w. That cable looks like its just delivering power straight to the slot, no regulation or filtering or anything in between so maybe just cut off the sata connector, splice on a molex / PEG / something else and see how you go.
Reactions: Thestarkiller32
jØrd
LOSIAS
Jul 19, 2015
818
1,359
Those flexi risers w/ the blue tape are notorious for being unreliable. There is a thread about flexi risers here. In an ideal world the less risers and cables and whatnot that your PCIe signal has to pass through the better.
