Storage Partaker B18 on AliExpress... 5x5 board with flat soDIMMs and 3xM.2!
Instran0
526
107
Another fun note - Unit seems to work fine on a 12v supply. My supplier forgot to pack the normal supply (which I thought was 19v), and I've been happily putting along with my functionality tests with a 12V/7A adapter.
if you had a powerful enough 12V supply, could it also be used to power a low-profile GPU ??
i want to use only 1 power supply, for both system and GPU.
low-profile GPU is connected via M.2 to PCIe adapter.
NateDawg72
398
302
Yes ?
As long as the adapter has external power input.
Also I apologize I haven't gotten anywhere with my build, renovations and work have kept me busy... My build should have a gtx 1660ti so I'm also planning to use an m.2 to PCIe adapter, and an internal 12v Psu
Reactions: NinoPecorino
CARC Mini
169
48
If you are designing a case for this, would people have to buy the complete mini pc or are the bare boards available somewhere?
just wanted to update this with the latest info.
this system is now available from aliexpress.com, in 10th Gen i9 and i7 CPU versions.
also, my custom case is now made out of metal. approximate dimensions - 222mm X 173mm X 69mm [ 2.65 litres ]
design credit to NFC Systems. here's a photo of its metal panel, before its folded to make my case :
REVOCCASES
REVOCCASES
2,237
3,652
www.revoccases.com
also, my custom case is now made out of metal. approximate dimensions - 223mm X 179mm X 69mm [ 2.75 litres ]
Nice. Just a few bends and you have a Skyreach Micro. :)
Any progress on your custom power supply? Will it match with the case design?
CARC Mini
169
48
NateDawg72
398
302
