Hi Everyone,
I'm trying to piece together my Velka 3 build, and would like your opinion on what I've come up with. Originally I was looking at the AM5 platform (ok, admittedly so I can get a copy of Starfield), but the mini-ITX motherboards seem quite expensive, and more than what I need. The best GPU that I can fit in the case (and is available in the U.S.) seems to be the Zotac 4060, so I don't think I need some crazy build to drive that card.
Here's what I come up with:
- Velka 3 Case
- Gigabyte B550I AORUS Pro AX AMD AM4 Mini-ITX Motherboard
- 5600X (or maybe a 5600 since it's a little less)
- Corsair Vengeance LPX 32GB 2 x 16GB DDR4-3200 PC4-25600 CL16 (can't find the height on these but I think they'll fit being low profile)
- SAMSUNG 980 PRO SSD 1TB PCIe 4.0 NVMe
- ZOTAC GAMING GeForce RTX 4060 8GB SOLO
- Noctua L9a-AM4 Chromax
- HDPLEX 400W HiFi DC-ATX
- Dell 7.4 mm barrel 330 W AC Adapter
Anything I should change or be concerned about? Thanks everyone!
Edit: I'm also considering a 5600X3D, since according to GamersNexus it only drew another 7 watts or so during an extended CPU test.
- Velka 3 Case
