D
Deleted member 3671
Guest
Hello everyone, thank you for stopping by to read my thread. Lets get down to brass tacks.
I have a fairly significant issue with my NF-A12x25's that I'm hope someone can help me solve.
When I connect 2 NF-A12x25's via the included Y cable > 4pin to mini 4pin adapter > GPU, while running 3d applications 1 of 2 fans will stop spinning at some point. It can be either fan, at anytime, but *seemingly* only occurs while I have 3d applications/games running. I have the rpm floor set roughly 3 times higher than the lowest rated rotational speed. Also, I know that the problem is not due to a faulty 4pin to mini 4pin adapter cable, Y cable, or GPU, because when I swap the NF-A12x25's for another other set of 120mm fans, this issue does not occur. I did seperate testing of each NF-A12x25 off of a M/B header and didn't notice any odd behavior. This issue persists across Precision X1, Afterburner, and while using no fan control software. Is it possible that the logic on the NF-A12x25's doesn't mesh well with my GPU in some way?
System:
Case: Ncase M1 v5
CPU: Intel 6700k w/Alpenfohn Atlas/Scythe Kabuto III
M/B: Gigabyte Z170N-gaming 5 rev.1
RAM: Corsair LPX 16GB 2133MHz
GPU: GTX 1080 Founders w/Artic Accelero IV
PSU: Corsair SF600
If it helps: there are a few other posts on Google searches about this specific fan and issues when being run on a Y cable, and/or off a gpu. If anyone has any idea what could be causing this behavior, or if you need more specific information from me, please let me know.
Thanks again for stopping by and taking the time to read my thread.
System:
Case: Ncase M1 v5
PSU: Corsair SF600
