XeaLouS submitted a new resource:
NoFan CR-80EH - 115mm passive cooler
156mm diameter (model is 156 due to reviews stating real size 1mm bigger than spec) and 113mm high.
Most of the stuff is accurate to 1mm. The plastic shroud isn't accurate at all apart from being correct for total model height.
Heatpipes were modeled off pictures and should start/end/curve within 1mm.
