I am installing a Noctua cooler (NH-C14S) with their Secufirm 2 system. One clamp comes into contact with the heatsink of my GSkill Trident Z RGB memory (due to the ram's 'thick' heatsink!) and pushes on it very slightly, causing the memory not in a 90 degree vertical position but inclines very very slightly. I wonder on the long-term effect of such a pressure on the memory slot.
So, does anyone have a similar situation with a Noctua Secufirm 2 on his Asus Z170/270/370i Gaming motherboard?
Edit 1
Well, I am impatient to see what you guys' experience are and so I go ahead and use a steel file to remove about 0.5 to 1mm material from the apex of the curve. Now, the clamp does not touch the memory heatsink. Problem solved!
If you had a similar situation before and solved it in some other way, please share in this thread.
Edit 1
