Picked up a NH-C14 from ebay and would like to replace the fans because they're getting old and are 3-pin (NF-P14 FLX). Ideally I'd like to get a black/grey one at least for the top as it can be seen through the M1 side panel.
Has anyone replaced the fans with 4-pin PWM models? If so which ones worked well?
After looking around the Noctua site it seems like the following ones could be options:
NF-A15 PWM 140x150x25: https://noctua.at/en/nf-a15-pwm/specification
NF-P12 redux-1300 PWM 120x120x25: https://noctua.at/en/nf-p12-redux-1300-pwm/specification
NF-A12x25 PWM 120x120x25: https://noctua.at/en/nf-a12x25-pwm/specification
NF-A15 HS-PWM 140x150x25: https://noctua.at/en/nf-a15-hs-pwm-chromax-black-swap/specification
This is for cooling a i7-9800X (165 W TDP). The original cooler that shipped with the NH-C14 can be found here: https://noctua.at/en/nf-p14-flx/specification
