I decided to do some top mounted fan testing on the Noctua L12 Ghost Edition cooler. I first replaced the included below the cooler B9x25 fan with the newer A9x25 fan before starting as it has both higher RPM range and higher static pressure. I initially wanted to compare the performance of top mounted fans in a dual downdraft configuration, but after noticing the top mounted fans reduced the maximum RPM of the bottom A9 fan, I also decided to compare the performance of the top mounted fans both with and without a lower fan. I also tried two front mounted (RAM side) fans as (case) fans with only a top mounted Scythe Wonder Snail fan for comparison.
Tested:
Noctua L12 Ghost Edition cooler with lower A9x25 fan only
Scythe Wonder Snail
Scythe Kaze Flex Black
Noctua A12x25
Phanteks T30
Noctua A12x15
Arctic P14
I included the Arctic P14 fan as it fit very nicely on top of the L12 cooler when mounted in my 5.9 liter Yiluka YLK01 case. The counter-rotating Scythe fans slowed the A9x25 fan the most.
Using a dual fan configuration with this cooler may well not be worth it. The Noctua A12x25 used alone was the quietest. At 100% PWM.
MakerBeam ITX Open Test Bench
Aorus B550 ITX MB; Ryzen 7 4750G; 32 GB Corsair LPX 3200 RAM; Metal block over NVMe drive not installed; Thermal Grizzly Carbonaut Thermal Pad
No Graphics Card installed
Noctua L12 Ghost Edition Cooler; Lower Fan: Noctua A9x25 (When Installed); Upper Fan (or Case Fan) see below
Open C of cooler faced towards unused graphics card slot. Cooler fins run front (RAM side) to back (IO side) of MB.
Blender Classroom Render & Unigine Valley Ultra Settings
Room Temp 21C; CPU & Case Fan(s) PWM 100%; Temp Sensor TZ10 read 16.8C on all test runs; (Case) fan placed blowing air on RAM side of MB
CPUID HWMonitor Readings:
After conducting the tests I realized that I also needed to reverse the (case) fan direction and add these results to the updated table:
Tested:
Scythe Wonder Snail
Noctua A12x25
Phanteks T30
Noctua A12x15
Arctic P14
Upper Fan | | Scythe WS | Scythe WS | Scythe KFB | Scythe KFB | Noc A12x25 | Noc A12x25 | Phan T30 | Phan T30 | Noc A12x15 | Noc A12x15 | Arctic P14 | Arctic P14 | Scythe WS | Scythe WS |
Lower Fan | A9x25 | A9x25 | | A9x25 | | A9x25 | | A9x25 | | A9x25 | | A9x25 | | | |
Case Fan | | | | | | | | | | | | | | Arctic P14 | Scythe KFB |
Blender Render Time | 10:30.08 | 10:22.45 | 10:21.40 | 10:23.94 | 10:19.92 | 10:23.15 | 10:21.00 | 10:22.00 | 10:20.13 | 10:25.49 | 10:21.15 | 10:24.45 | 10:23.26 | 11:00.70 | 10:21.98 |
Temp Sensor 0 | 43 | 38 | 37 | 37 | 38 | 37 | 38 | 37 | 37 | 39 | 41 | 37 | 39 | 37 | 35 |
Temp Sensor 1 | 44 | 40 | 40 | 39 | 41 | 39 | 40 | 39 | 40 | 40 | 43 | 39 | 41 | 39 | 38 |
Temp Sensor 2 CPU | 74 | 68 | 66 | 67 | 67 | 67 | 67 | 66 | 66 | 68 | 69 | 66 | 67 | 66 | 65 |
Temp Sensor 3 PCI | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 |
Temp Sensor 4 | 44 | 40 | 39 | 39 | 41 | 39 | 40 | 39 | 39 | 40 | 42 | 39 | 41 | 38 | 38 |
Temp Sensor 5 | 42 | 37 | 37 | 36 | 39 | 37 | 38 | 36 | 37 | 38 | 41 | 36 | 39 | 37 | 35 |
CPU Pkg Max Temp | 74.6 | 68 | 66.9 | 67 | 67.8 | 67 | 67.5 | 66.5 | 67.1 | 68.6 | 69.9 | 66.8 | 67.6 | 66.4 | 65.1 |
CPU Pkg Max Wattage | 89.01 | 88.8 | 88.85 | 89.09 | 88.87 | 89.06 | 88.89 | 89.93 | 88.85 | 89.01 | 88.78 | 88.82 | 88.89 | 88.91 | 88.83 |
NVMe Top 970 Evo + | 43 | 38 | 37 | 37 | 38 | 37 | 38 | 37 | 38 | 39 | 41 | 37 | 39 | 41 | 37 |
I-GPU Max Temp | 64 | 57 | 58 | 57 | 58 | 57 | 58 | 57 | 57 | 58 | 60 | 57 | 58 | 56 | 55 |
CPU Lower Fan Max RPM | 2045 | 1934 | | 1928 | | 2002 | | 2002 | | 1991 | | 1985 | | | |
CPU Top Fan Max RPM | | 2331 | 2337 | 1646 | 1634 | 2057 | 2057 | 1979 | 2020 | 1824 | 1767 | 1614 | 1662 | 2327 | 2327 |
Case Fan Max RPM | | | | | | | | | | | | | | 1721 | 1573 |
Upper Fan | | Scythe WS | Scythe WS | Scythe KFB | Scythe KFB | Noc A12x25 | Noc A12x25 | Phan T30 | Phan T30 | Noc A12x15 | Noc A12x15 | Arctic P14 | Arctic P14 | Scythe WS | Scythe WS | Scythe WS |
Lower Fan | A9x25 | A9x25 | | A9x25 | | A9x25 | | A9x25 | | A9x25 | | A9x25 | | | | |
Case Fan | | | | | | | | | | | | | | Arctic P14 | Scythe KFB | Scythe KFB |
Blender Render Time | 10:30.08 | 10:22.45 | 10:21.40 | 10:23.94 | 10:19.92 | 10:23.15 | 10:21.00 | 10:22.00 | 10:20.13 | 10:25.49 | 10:21.15 | 10:24.45 | 10:23.26 | 11:00.70 | 10:21.98 | 11.0793 |
Temp Sensor 0 | 43 | 38 | 37 | 37 | 38 | 37 | 38 | 37 | 37 | 39 | 41 | 37 | 39 | 37 | 35 | 36 |
Temp Sensor 1 | 44 | 40 | 40 | 39 | 41 | 39 | 40 | 39 | 40 | 40 | 43 | 39 | 41 | 39 | 38 | 39 |
Temp Sensor 2 CPU | 74 | 68 | 66 | 67 | 67 | 67 | 67 | 66 | 66 | 68 | 69 | 66 | 67 | 66 | 65 | 65 |
Temp Sensor 3 PCI | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 | 21 |
Temp Sensor 4 | 44 | 40 | 39 | 39 | 41 | 39 | 40 | 39 | 39 | 40 | 42 | 39 | 41 | 38 | 38 | 39 |
Temp Sensor 5 | 42 | 37 | 37 | 36 | 39 | 37 | 38 | 36 | 37 | 38 | 41 | 36 | 39 | 37 | 35 | 36 |
CPU Pkg Max Temp | 74.6 | 68 | 66.9 | 67 | 67.8 | 67 | 67.5 | 66.5 | 67.1 | 68.6 | 69.9 | 66.8 | 67.6 | 66.4 | 65.1 | 65.5 |
CPU Pkg Max Wattage | 89.01 | 88.8 | 88.85 | 89.09 | 88.87 | 89.06 | 88.89 | 89.93 | 88.85 | 89.01 | 88.78 | 88.82 | 88.89 | 88.91 | 88.83 | 88.91 |
NVMe Top 970 Evo + | 43 | 38 | 37 | 37 | 38 | 37 | 38 | 37 | 38 | 39 | 41 | 37 | 39 | 41 | 37 | 37 |
I-GPU Max Temp | 64 | 57 | 58 | 57 | 58 | 57 | 58 | 57 | 57 | 58 | 60 | 57 | 58 | 56 | 55 | 51 |
CPU Lower Fan Max RPM | 2045 | 1934 | | 1928 | | 2002 | | 2002 | | 1991 | | 1985 | | | | |
CPU Top Fan Max RPM | | 2331 | 2337 | 1646 | 1634 | 2057 | 2057 | 1979 | 2020 | 1824 | 1767 | 1614 | 1662 | 2327 | 2327 | 2319 |
Case Fan Max RPM | | | | | | | | | | | | | | 1721 | 1573 | 1558 |
Case Fan Direction | | | | | | | | | | | | | | Intake | Intake | Exhaust |
