NH-L9a/i 120mm bracket?
EM98xXkillerXx
26
Does anyone know if there is one of these? If not how easy would it be to make one? Could I just get some small steel pieces and drill holes in them to move the fan holes over or something? Something like this thing i found on ebay (to give an idea) https://www.ebay.com/i/262959653264?chn=ps&dispItem=1
Another idea is to 3D print something similar to the c7 120mm bracket, but I'm no expert on messing with 3d objects...
4,783
Yup, simple brackets like that would work. Just be sure to account for the height of the screw heads if you go that route, to clear them will increase the height a few mm over the stock setup.
