New revision of Ncase M1, when?
CALiiGeddon
I can't wait until the next round opens up. I already have my parts coming in the next 2-3 weeks and will just have it all built on the side waiting for the case. Everyday I check the website waiting for first opportunity to order it.
CALiiGeddon
Just pre ordered mine a few hours ago when some became available. Now to play the waiting game. My build is a 9900k with a 2080 and a 4tb 860 Pro. The next generation graphics card is when I'll buy the top tier card.
D
Deleted member 12074
Guest
You guys here really should all switch to this thread. Necere opened it himself and you can find all the information there. The notification mail a few days ago wasn't the second preorder run, these were just cancelled orders from the first run becoming available again (two units per color only). There's no need to mash F5 on the store page, there will be a second run mid/end august. Necere will anounce it in the linked thread. In the first post of the thread you can also find an FAQ.
C3N0B1T3
55
40
Looks like pre-orders are open again guys. I've been mashing the F5 key and found out that way. Didnt get a re-stock email. Good luck.
Terse
These are cancellations, that's how I got mine. Look soon for a bigger block of reservations for the next wave.
maveric
27
Now that V6.1 has been available for some time, does anyone have any idea when the next revision will be released? Thanks!
Blubbie21
34
21
Deutschland
Hello Fellow SFF Builders and Creators,
since the GPUs increased in size over the years i would be happy to hear about a potential update on a new NCase M1 Revision what is a bit wider in terms of GPU support.
Currently only NVidia cards with reference pcb (112mm height) and Founders Edition will fit with a WATERBLOCK into the NCase.
It would be nice to have a more future proof and wider case. So you could also fit 120mm (height) GPUs like the ones from AMD into this case with a waterblock attached.
So - are there any plans for a new version of this beautiful case with slight increase in width?
Reactions: millerbedicks
Wahaha360
a.k.a W360
2,131
10,697
USA
IIRC, I think it's mostly done, Necere just has to make a decision on some details and execute.
