Repost of what I posted on Reddit here. This is my new Cooj MQ6 build I completed last night.
Photos here: COOJ MQ6
Size comparison photos: Size comparisons
This is a secondary PC intended as an HTPC to match with my projector (JMGO N1 Ultra) that I recently got over the Summer. The GPU was not my first choice. Sadly, AMD 7700XT variants in this size at 200mm in length are not being made.
Build:
Excellent build quality as expected from Cooj. I initially ordered the case in June & receive it in August. I delayed the build due to missing some parts. The case is very small so it needed more elbow grease than usual but I was successful. I was concerned that the cooler (Noctua L12S) would not fit but fortunately, that was not an issue. The CPU choice is ideal for the cooler. I do not intend to upgrade it for a good while other than the GPU in the future.
Final Thoughts:
I'm pretty satisfied with this build, especially the aesthetics. I initially thought of getting a FormD T1 but thought against it as I have no intention of replacing my main rig (Silverstone SG10).
- Case: COOJ Sparrow MQ6
- Power Supply: Enhance ENP-7660B 600w
- CPU: AMD 7800X3D
- Motherboard: Asus ROG Strix B650e-i
- Memory: 32GB Gskill Ripjaws DDR5 6400
- Cooler: Noctua NH-L12S
- Fans: 2x Silverstone Air Slimmer 120 (Black) for CPU & top case fan
- GPU: Gigabyte RTX 4060ti 16GB Windforce OC
- Storage: HP FX900 Pro 4TB NVMe
Build:
Final Thoughts:
