Prebuilt New AliExpress mini PC - i9-9900 with a GTX 1650 - Only about 2.5L volume!
thewizzard1
327
246
@Goatee when you plug your 19v adapter into that barrel connector, what voltage comes from the PCIe power connector?
Hector
In the description it says it can accept max 200w power. If the 6 pin power for the GPU could come from somewhere else, could this be overcome? I would like to put a rtx 2060 in this, but it specifies maximum gtx 1050ti, due to this power limit.
dzungitx
26
Don't buy, just do it ?
watts_happening
25
36
Thank you for the lead on the TH310C-P board. Just ordered one... will see how long the slow boat takes to deliver it.
Plan is to make a DIY passive i7-9770F/1650 built around a giant heatsink. It will replace my 5 year old Gigabyte Brix Pro 4770R that's hacked into an Akasa Euler case with a custom aluminum adapter block. The Brix still works great and is silent, but the graphics performance is not very good by modern standards.
I was considering the ASRock IMB-1213 or IMB-1215, but they're either hard to find (1213) or expensive (1215). Taking a chance on a generic this time around.
