i am closing in on my first sff build, here are the parts i have (almost) decided on:
case: ghost s1
mobo: asus x470- i gaming
cpu cooler: noctua nh-l12
cpu: 2600x or 2700x
gpu: evga 2080 ti xc or custom cooled 2080ti
ssd: 1 or 0 sata ssds, 1 or 2 m2 ssds
pslate customs cables
small or mid tophat with 15 or 25 mm noctuas
i have a couple questions:
1: is there anywhere to put an ssd in the case that will not reduce airflow? i have a ssd i'd like to reuse for this build, but i am willing to sacrifice it if it reduces the airflow and increases heat/noise from the system and just use m2 ssd(s). will a m2 on the back of the mobo reduce airflow?
2: is there any other 2080ti variant that is more quiet than the evga xc? does anyone have experience with custom cooling for the 2080ti?
3: does anyone know how much cpu temps affects gpu temps in the ghost? will using a less powerful/cooler cpu make it easier to cool the gpu? i was planning on using a 2700x but will go for a 2600x instead if that makes the system quieter. does anyone recommend other cpus that are cool/quiet while still not bottlenecking a 2080ti in 4k?
4: is there a big difference in temps/noise between the 15 and 25 mm top noctua exhaust fans/the s or m tophat? will adding a s tophat on the bottom help with cooling?
i will be using the system for portable 4k gaming. i know that it is very hard to have a system that is both powerful, small AND quiet, but i want to have the system as low noise as possible. the system has to be aircooled, i might have to have it in my hand luggage, and getting watercooled systems through airport security can be a hassle from what i have heard.
any help would be greatly appreciated
case: ghost s1
cpu: 2600x or 2700x
