Need help RVZ03 RX 590 wont reach PCIE
stoyo889
Hi all,
I checked the dimensions of the RX 590 and it should fit the in the RVZ03. I took out my GTX 1060, and when I slot the 590 into the Riser/plastic GPU holder the GPU bracket slots in fine (rear io thing). The issue is, the 590's PCIE connector is just slightly above the PCIE connector on the riser. I couldnt see how the riser connector can be moved/adjusted? Am i missing something here?
Goatee
739
1,513
Hi all,
Have you got the extension piece still attached to the 1060?
Reactions: loader963
stoyo889
Hi Goatee,
Lmao that may be the problem. I will check tonight, this happen years ago to me with another small build... i was so stressed last night.
