Mates,
I was hoping for some advice, suggestions on my 1st ITX build.
- Usage
1 platform PC for PUBG + Streaming. (streaming is just a hobby)
CPU/GPU: Prob not OC
Ram: OC
- The Line-up
CPU: AMD Ryzen 2700X
Motherboard: ASUS ROG Strix X470-I
GPU: ***1*** (one from 1080 ti) (3-fanned, open-air type?)
Memory: ***2***
G.Skill Trident Z RGB DDR4-3200 14-14-14-34 (F4-3200C14D-16GTZRX)
or G.Skill Flare X DDR4-3200 14-14-14-34 (F4-3200C14D-16GFX)
or suggestion of your choice (over 3200mhz, samsung b-die based)
Storage: Samsung - 860 Evo 1TB 2.5" SSD
PSU:***3***
CPU Cooler: ***4*** (up to 65mm in height)
Case Fan:***5*** (15~25mm in height) (2 case fans mounted on top with M top-hat, 1 fan under PSU)
Case: Louqe Ghost S1 (ITX)
*I need advise on ***#*** (5 areas).
But suggestions on any other areas and/or just on anything in general would be really helpful.
Thanks.
- Usage
Ram: OC
- The Line-up
Memory: ***2***
PSU:***3***
Thanks.
