Ncase m1 v6 noctua fan orientation
jdlim07
Hi guys pretty dumb question so this push pull setup with u9s which way should the fans be facing with the logo on both sides
HyperActive
183
75
There are arrows on the fan indicating the blow direction. Best setup for v5 was u9s as intake, since the cooler is so close to the side for fresh air.
Reactions: jdlim07
HyperActive
183
75
You mean a side fan? Not the case fan on the back? All you need is 2 fans in the u9s (except of you rock a ryzen 9 3900x or intel i9 9900k
Reactions: jdlim07
jdlim07
My layout is correct apparantly base on the airflow in ncase post. I kept on messing around with the fans because my 9700k oc to 4.7ghz was reaching 95c on stress tests and 85peak on gaming turns out I just need to lower my volt from 1.275 to 1.215 and now stress test peak temp was only 79c!
