I've been thinking about water-cooling my NCASE M1 for a while now, but wasn't planning to do it until much later this year.
However, given that my IceMan Cooler Pump Reservoir arrived yesterday and then EKWB announced a 10% Off Everything sale for this weekend only, I've decided to at least try to buy all the stuff I need for a custom loop now, even if I only do the build in a few months time.
The problem is that I've only ever built air-cooled PCs, and while I have a general idea of what I need, I don't have an exact shopping list. The configurator on EKs website wasn't very helpful either.
So, I need some help from someone who's already been through this before and can help me pick up all the right parts to complete the loop.
Let me start off by telling you what needs cooling, and the few items I've already purchased:
My Current Build
I need everything else, and my priority this weekend is to order as much as I can from EKWB. I'll worry about changing my motherboard, and getting customs cables later.
What I Think I Need...
Do you think I can run the whole loop off a single 240mm radiator with the Phanteks T30 fans, or will a second radiator be necessary? I'd prefer not to be running my fans too loud, or I won't have gained much from moving to a water-cooled system.
Any assistance here will be greatly appreciated as I only have about 36 hours left to get my order together!
My Current Build
NCASE M1 v6
AMD Ryzen 7 5800X
MSI B550I Gaming Edge Motherboard (Looks like I'll need to change this because of CPU waterblock compatibility, ideally to the ASUS ROG X570-I)
EVGA GeForce RTX 3080 XC3 Ultra (The EK-Quantum Vector2 XC3 looks like a good option here)
2x Noctua NF-A12x15 chromax fans (I hope these will work for a bottom mount slim radiator if I need one)
Purchased AlreadyIceMan Cooler NCASE v6 Pump Reservoir
Alphacool DDC310 DDC Pump (with IceMan Cooler DDC Cover)
3x Phanteks T30 120x30mm Fans
EK-Quantum Vector2 XC3 RTX 3080/90 Nickel + Acetal GPU Waterblock
EK-Quantum Vector2 AM4 Nickel + Acetal CPU Waterblock
EK-Coolstream 240 Radiator for the side panel. - I'm not sure about the difference between the Classic PE 240 and PE 240 (Dual)
Leak Tester and Tube Cutter
Beyond this, I know I need compression fittings, soft tubing, and coolant, but I have no idea how many, or how much of any of them I need.
As I haven't fitted a waterblock to a GPU before, I'm not sure how much space I have to play with at the bottom of the case. I see EK has a slimmer SE range of radiators, but there's also the XSPC TX240 Ultrathin radiator as an option.Do you think I can run the whole loop off a single 240mm radiator with the Phanteks T30 fans, or will a second radiator be necessary? I'd prefer not to be running my fans too loud, or I won't have gained much from moving to a water-cooled system.
