Watercooling Ncase M1
RZEX
Hi everyone, I am a PC enthusiasts from Taiwan.
This is my second time on an itx build, and my first time for a custom loop.
I spent almost a month to finish this build.
Here's my loop
Pump/reservoir -> CPU -> GPU -> 240 radiator -> 92mm radiator -> Pump/reservoir
For the pump/reservoir part, I've tried barrow's DDC and aquacomputer's D5.
Barrow's DDC is loud even in 3000 rpm, D5 is too big for an itx build. Finally I got a DDC310 from alphacool.It works well and quietly. With EK-XRES 100 DDC - Acetal, it's low enough to put it in the case.
For the GPU part, it's hard to found a waterblock for EVGA 1080ti sc2. I got one from bykski. However, it's a little bit big in ncase. So I got a L-shape block for it and use a thin radiator to fit them inside the case.
To have more cooling capacity, I bought a 92mm radiator and put it at the rear of the case.
For the custom cable, I got 40cm for CPU, 25cm for 24-pin, 18cm for GPU and 15+5 cm for SATA.
Since it's the first time for me to to the custom loop, I got a lot of fittings rather than bend the tubes.
Maybe I'll bend them more in the future. And I'll buy higher feet for the case.
RZEX
I bought them separately. DDC310 from alphacool and EK-XRES 100 from EK.
foo
That is one slick build. Nicely done! You should post a parts list. Very well done....
RZEX
CPU: AMD R7 2700X
MB : ASUS X470-I
GPU: EVGA 1080TI SC2
RAM: G.SKILL TridentZ RGB 3200 C14 8G*2
SSD: Samsung 970EVO 250G
MX-500 500G
HDD: HGST 2.5inch 1T
PSU: Corsair SF750
CPU : EK Supremacy EVO
GPU : Bykski N-TITAN-PAS-X
PUMP: Alphacool DDC310
Barrow FITTING
Barrow 1410 fitting
XSPC TX240
Alphacool XT45 92mm
Noctua A12X15
Noctua A9
Reactions: Boil
RZEX
The ambient temperature it around 30, and idle temp for CPU and GPU is about 40.
When I played PUBG, the temp would be about 70~75.
Reactions: Boil
