NCASE M1 upgrade from ML-08. Need anything else?
smalltime
Hi! I'm buying an M1 V5, and would like to know if my current hardware will fit.
Gigabyte Z170N-Gaming 5
GTX 970 GPU
Big Shiruken Fan
Silverstone ST45SF-G 450W Power Supply
950PRO SSD
Anything look suspect? Am I good to go with just the case?
2,669
2,793
The only potential problem would be the GTX 970 and that depends on which one you are using. You have 370mm X 140mm for the GPU, just make sure yours is within those sizes. Cards like the MSI GTX Gaming is just a bit too wide and you might not be able to close your side panel completely. The Zotac AMP is too wide, most other GPUs will fit.
Reactions: smalltime
