Damn that looks good. How are your temps on the 8700k after delidding it?
This build is so amazing. This really fueled my drive to go custom watercooling in this case.
Im SUPER exited to see temps on this!! Plz hurry and get those public!
Im curious as to what you would think about a single 280rad in push for cooling this case. The bottom being w/o rad might introduce cooler air to the rest of the case? What do you think? Cheers.
I don't have any before delidding temps. I delidded the processor before I even installed. Unfortunately, I haven't had much time for testing, but I'm sitting at an overclock of 5 GHZ at around 1.3v. I still have some stress testing to do and fan profiles to work out.
Gaming temps varies due to the fact that when the overclocked Titan Xp gets pushed, it affects the temps of the whole loop. For example , a game that really utilizes the cores, and I'm gaming at 4K with this setup, things can really heat up. Then the temps are also affected over time as the liquid gets warmed up. I've seen temps while gaming as low as 45c CPU and 50c GPU, or as high as 70c CPU and 70c GPU depending on the game. Also, an increase in one temp affects the other.
I still have some tweaks and testing to do. I'll post some more definitive numbers once it's all done.
I don't see a problem with using a 280 rad in push with a fan on the bottom for intake. Of course your temps will vary based on your hardware and settings (overclocking, etc). Almost all these parts were transferred from another build. Since I already had a 240 rad and I wanted to put as much rad as possible, I added the 120 rad at the bottom.
@Nwkrep82
I have a 270i and a 7700k, and at even mild overclocks, loading the CPU will result in coil whine from the motherboard. Different sources of 100% load will result in whine of a slightly different pitch/character.
- have you noticed (on your 270i or 370i) any 'coil whine' type load coming from your motherboard VRM?
It's not super important for me, as I know this whine will be inaudible once the rig is in a case, but I'm trying to collect more data.
Great job with the shift-x, BTW. Stellar work. Also heartening to know that the monoblock fits on both. Truly a new architecture
I haven't heard/noticed and sort of whine on my setup.
@Nwkrep82 Another thing.
Can you go over how you hooked up your commander pro? Do you have a usb2 adapter on the usb3 mobo header? And how did you do the LED setup?
Sure. First, I'm using all Corsair fans (HD120 and HD140), and their Lighting Node Pro led strips. All the fans are powered by the Commander Pro. If you look at the pic I have posted, you can see all six fan inputs filled up.
To control the RGB LED portion of the fans, you must use the hub that comes with the fans (when you buy the kit). All the RGB LED fan cables plug into that hub. You can see that smaller hub in that same pic. Then a cable (included with the Commander Pro) goes from that hub to one of the LED ports on the Commander Pro.
The RGB strip is plugged into the second LED port on the Commander Pro with the others daisy chained to the first (I using three RGB LED strips).
As for USB connectivity, I'm using an
adapter cable, USB 2.0, IDC 5 Male (single row) to USB A Male. That cable is plugged directly to the motherboard rear panel I/O. That was due to the lack of an USB 2.0 header on the Asus Strix Z70i. I just kept the same connection with the Z370i.
