Hello, Been lurking here for a good bit. Finally got my build almost squared away so figured I'd share. This is my daily driver "big" machine (got a smaller build in the works )
It's based off a Jonsbo c6 (no not the ITX....would have made things easier but I've had this longer than the ITX I think?)
It started life as a mATX 13100 with an ARC A750 stock cooler.
Now it sports a 12600k ITX with B580 and somehow I crammed a Noctua D15 in it with a single fan, plus two 140mm noctua case fans. PSU is a EVGA BP650.
I need to design/print a new top fan bracket and psu bracket for the top as well. Then print a vented filler plate for the stock psu mounting location, a little more cable management then call it day for this build.
But as it stands it works out great. I did try going with the conventional setup and the AXP90 X47 FC cooler and 3 120mm fans but it ran hot even with the cpu undervolted and still throttled. Now it seldom goes over 70c and that's with the fans in "silent" mode.
The GPU barely fits lol....it touches the front panel but still fully closes. Anywho I'll update this once it's done done.
Oh and here's a little teaser for the little guy
