[HELP] JONSBO U1 WITH 2700X
ROOTWANG
Hi new to this great community and i wanted to ask for some advice on a sff build
I want to use this parts https://pcpartpicker.com/list/jwPtdX on theE JONSBO U1 PLUS CASE (i can found it for a resonable price on ebay) do you think it can work (temp Wise)
The other idea is to use the Kolink rocket with the non x version (65W TPD)
Do you have any advice or experience on this case? Or some general advice? It's my first mini ITX build BTW
Thank you!
dealda
47
24
Hi,
I have recently moved my system into a U2.
While these are goodlooking cases with a small footprint, the thermals are not great.
Especially with a glass panel at the side.
For reference:
my system (I5-3450 with undervolting/1060 with Noctua fan instead of the stock fan)
Cooling 2x120mm Noctua redux casefans@7V/Noctua U9B Se@7V/Noctua a9 pwm fan on the Gpu
Under Load my Gpu Temps are around 70°C/Cpu are around 55°C
Your parts are going to run rather hot in this case.
The RX 580 does not fit in the U1 either, so you need to choose another case or another card (1060/480).
There is also no cpu cooler (aside from the stock cooler) in your list.
The Corsair sfx psu seems to have rather thick sleeved cables, which look nice but I would prefer a Psu with flat cables (Silverstone;Sharkoon;Bequiet)
ROOTWANG
Well Thank you very much for the advice it's my first time building a sff mini ITX and apart for being a little confused, i can't find a case where i can put a 2700x and have good temp without undervolting i think i give up on a very small case for having a better temperature. I've seen a better case from lian li http://www.lian-li.com/pc-q38/ but i don't know if this will be good either...
TRBZN61
Look here:
