My first SFF build, trying to strike a balance among performance, appearance, compactness and noise etc
↓ Added two pieces of dust screen at the top, but perhaps they will just trap the heat inside
↑ Installed a typec-to-19pin converter so the front-facing usb-c port will be working.
With my niz 68 keyboard on top, just the same size.
Thanks for stopping by.
Just touching the mobo tray.
Will 3dprint a frame to fit an A4x20 for the front M.2. A 10 deg temp drop is expected.
Components:
- B460 + i5-10400 + 16G + 1660super (cpu undervolted by 0.125V for)
- SN750 500G + SN550 1T
- L9i chromax.black + 2 * Thermalright 9015
- PSU SF450 Platinum
More pics:
Update 1:
Applied this copper plate with graphite coating to the backside m2 -> a 5 deg drop in temp during cpu full load.
