Log My First mini-ATX SFF Build
newdriv
I'm a big fan of mini PCs and have experimented with models from various manufacturers. However, I found the customization options limiting, so I decided to build my own custom SFF (Small Form Factor) PC.
This is my first attempt, and I'd love any advice on cable management, as it's currently a bit messy.
Components Used
  • CPU: AMD 8600G
  • Cooler: Thermalright AXP90-X47 Full Copper Low Profile CPU Cooler
  • Motherboard: ASRock A620I LIGHTNING WIFI
  • RAM: G.SKILL Ripjaws S5 Series 64GB (2 x 32GB) DDR5 5200 (PC5 41600)
  • Storage:
    • 2x WD_BLACK 1TB SN850X NVMe
    • TEAMGROUP T-FORCE VULCAN Z 1TB SSD
    • Crucial 128GB SSD
  • Case: AliExpress Mini ITX Case
Challenges Faced
  1. PSU Noise:
    I wanted to avoid using Pico or Plex PSUs due to noise concerns, so I opted for the HD Plex instead.
  2. Direct Power Input:
    I wanted to avoid barrel plugs and charging adapters, so I implemented a direct input setup. However, no case I found included a C14 cutout, so I had to create one manually using a CNC machine. Unfortunately, no pre-built cases met all my requirements.
Suggestions for HD Plex
  1. Improved Mounting Options:
    Mounting the HD Plex was challenging due to the limited screw and mounting hole options. Including more screws and mounting configurations would greatly simplify installation.
  2. Dual Input Plugs:
    Adding dual input connectors for both C14 and C5 plugs would be a fantastic feature, allowing users to switch between them as needed.
If anyone has tips for cable management or other feedback on my build, I’d greatly appreciate it!
Let me know if you’d like additional tweaks!
