My first build into the Ncase M1 v1, coming from a temporary Coolermaster Elite 130:
Watercooling build using a Swiftech H220 and EKWB Full Cover block for R9 290X:
Results:
Upgraded the board to an Asus Maximus VII Impact and changing the radiator around:
After the waterblock on the GPU had a leak (along the seal), I choose to go back to aircooling:
After some solid advice from a forum member on another forum, I switched the GPU fans to exhaust along with adding an intake fan, I also installed a new SFX-L PSU :
And now I am in SFF Nirvana, with a quiet and cool high-end system !
Results:
These are three screenshots overlapped. Using Unigine Valley benchmark (like I did with watercooling) I tested with no V-Sync after about an hour, the middle one shows with V-Sync after 5 minutes and the right one shows about a minute of idling afterwards. Much more quiet in all those stages than the previous watercooling with no meaningful differences in temperature. Mind you I don't care if my CPU is 50° or 70°C, as long as it's not close to it's maximum allowed temperature, it performs the same and it will last much longer than I'll intend to be using it.
Results:
Results:
