Image Credit – MSI at CES. I like the 80s vibe of it. Matches my latest Trapper Keeper.
MSI has shown it’s new Meg Trident X2 system at CES, which is now available for pre-order. Coming in 22L, the uniquely asymmetrical shaped system has a cooling focus with a mesh intakes on the top and mesh exhaust on the side. Included inside is a 280mm AIO that exhausts out of the right side of the case. The GPU is an inverted mounting and draws air from the top of the case. The PSU, a 750 watt SFX unit, draws air from the bottom of the case. The current listed specs include an Intel i9-13900KF, RTX 4090, 64GB of DDR5-4800, 2TB PCIE 4.0 NVME SSD, 2X Lan ports, and a front mounted LCD display that allows users to control aspects of MSIs control center application. Expansion options include room for an two additional 2.5 inch drives...
Continue reading...
