Hi All,
I did my first mini-itx build and love it! So much in fact that I want to sell a few of them on ebay in my country. I was just wondering if you have any improvement suggestions. I have two versions a GPU-less "workstation" and a "gaming version". Things to keep in mind: I want to keep it quiet, and "lower-ish" energy consumption, hence why i didnt go with the max GFX card I could fit. But maybe you have suggestions here. Secondly, I want to keep the costs low, so not going for the biggest, most expensive components but rather best bang for your buck components as I will plan to sell a few of these.
GPU-Less (work machine):
Upgraded CPU and GFX Card (for work + gaming):
One idea I had was to swap out the 400w hdplex for a pisco since I dont think i need that much power in the GPU-less version and its a bit overkill, maybe there is a cheaper 150-200w pisco psu or something, could reduce cost and also open up more space in for airflow and viewability (case has transparent top).
Thanks,
My Build - Mini-ITX + GPU-less
pcpartpicker.com
System Builder
pcpartpicker.com
Thanks,
