Mineral-oil cooled SFF
Shahmatt
101
53
Well in the world of small form factor the main problem is that air cooling is less efficient than it otherwise might be. Cooling is heavily reliant on casing shape due to necessary access to vents or proximity to sides for use of passive methods.
I wondered then if mineral oil could be a good solution. The casing shape can be anything really as long as the oil is sealed in properly. All you need to do is to establish some liquid movement around the hot areas, but the normal fans (or bubbles) could do that. Also the weight penalty of carrying liquid around is reduced due to lower case volumes.
thewizzard1
344
254
Having to seal everything up is counter-productive to the size and portability ITX and SFF provide.
Josh | NFC
Not From Concentrate
NFC Systems
Jun 12, 2015
1,869
4,468
www.nfc-systems.com
As long as we are talking about submerged innovators, remember these guys?
https://theawesomer.com/reactor-oil-cooled-pc/5173/
This was the coolest thing in early 2008. So much custom work, and so many innovative ideas that were way ahead of the curve.
jtd871
1,166
851
Eventually, though, you need to transfer that heat to the air, and most oil-cooled PC projects that I have seen were not that portable - mostly due to weight/bulk of oil required to immerse an entire PC.
